» Silent Chain
Companies in Silent Chain
Gates Corporation
Gayatri Gear Industries
Maguire Technologies
Melfast
Ming Chang Traffic Parts Mfg.
René Baer AG
Serapid Inc.
SKF USA Inc.
Sprockets Australia Pty. Ltd.
Team Industries
Tsubaki of Canada Limited
VL Motion Systems Inc.
