Cortec Shares Rust Prevention Technologies
Today’s emphasis on sustainability and the circular economy may leave some manufacturers wondering, "Can I really get the results I need while increasing my use of biobased content?” Cortec shares two viable rust preventatives that allow users to go as high as 72 or 99 percent biobased content for metals protection in humid environments.
Canola Oil Based Rust Preventatives
EcoLine 3690 and EcoLine 3220 are two wet film rust preventatives from Cortec Corporation. Each includes a special package of corrosion inhibitors in a canola oil base for protection in high humidity conditions. EcoLine 3690 contains 72 percent USDA certified biobased content. EcoLine 3220 goes even higher; it contains 99 percent. USDA certified biobased content. Both can be applied by spray, brush, or dip like traditional wet film rust preventatives, leaving behind a tenacious oily film that clings to metal surfaces and provides excellent contact corrosion protection.
Where to Use EcoLine 3690 and 3220
These two temporary biobased coatings can be used in a variety of applications. Among the most common is rust prevention in various stages of the manufacturing process or during storage and shipment. EcoLine 3690 and EcoLine 3220 protects both ferrous and yellow metals and can be applied to wire, sheet metals, pipes, flanges, gears, and equipment. Furthermore, a low pour point of -0 °F (-18 °C) makes EcoLine 3220 good for application in cold conditions where other rust preventatives might freeze.
Biobased Rust Prevention in Action
