Design Components Controls Hybrid Servos Motors Servo Motors Servos Step Motors Technical Articles Force
Closing the Loop around a Transverse Flux Hybrid Step Motor
Transverse magnetic flux motors -- also known as step motors -- become Hybrid Servos when you operate them closed loop. This is the same transformation that happens between running a 3-phase synchronous motor from line voltage as opposed to running it closed loop as a brushless servo. In the case of hybrid motors, there are many degrees of what is advertised as "closed loop," and thus significant differences in the performance improvements seen.
This article appeared in the August 2020 issue.
