Black Bruin Offers Hydraulic Technologies at IFAT 2022
The S-series hydraulic motors from Black Bruin are designed for demanding recycling applications with direction changes and shock loads, which can be hard on shredders and their rotors. The power of the S-series helps handle varied and inconsistent waste material effortlessly and clears jams with ease. The torque transmitting components are easy to service to ensure maximal uptime in your application.
Built with robust piston design, the S-series motors are meant for heavy-duty action. Low surface pressures between cylinder block, cam ring and piston are the secrets of the S-series motor’s durability and long life.
For shredding systems where compactness combined with high efficiency are the key factors, the original Black Bruin motor design with rotating case may well be the most efficient choice, offering process reliability and high uptime in these applications. Design advantages include easy installation, extended bearing life and more. With bi-directional multi-speed function these motors offer optimum torque in applications demanding constant direction changes and variable loading.
Black Bruin will showcase its hydraulic direct drives at IFAT 2022, Munich, May 30 - June 3 at Stand 119, Hall B5.
