Power Transmission Engineering (PTE) Has Your Bearing Education, Training, and New Developments Covered Every Issue
February 14, 2017
PTE covers bearings in every issue, from application stories to technical articles and the latest technology from the major suppliers. Here is a selection of some of our most recent and most popular articles on bearings:
in the performance and life of
a rolling element bearing. Less
than 10 percent of bearings reach their theoretical L10 life, and poor lubrication can be attributed to 80 percent of those that fall short. Ideally, a lubricant forms a film layer between moving components in a bearing, separating moving parts, minimizing friction and
preventing wear between balls or rollers, raceways and retainers. Lubricants also protect metal surfaces from corrosion and moisture, dissipate heat and can even prevent the ingress of contaminants.
