Emerson Bearing, a Boston, MA-based bearing company catering to niche markets nationwide and the sister company of Action Bearing which serves the New England market, announces the availability of a complimentary E-Book and other online resources for Type E Mounted Bearings.
KISSsoft has announced that NSK has provided their extensive bearing data “catalogue data” for inclusion in KISSsoft software with release 2023. With this, the engineer can execute static rating, basic and modified life rating based on load capacity numbers in line with ISO 281 and ISO 76 along with thermal rating. The bearing database in KISSsoft gives access to up-to-date NSK bearing data in an easy to use yet detailed manner using the shaft-bearing system modeler.
A hydro turbine company based in Portland, Maine, has chosen Vesconite Bearings’ lowest-friction material for the thrust bearings on its free-stream turbines.
FDA/USDA certified, two, three and four post, stand-off bearing flange blocks are setting a new standard for performance and hygienics. These new stand-off bearing flange blocks now available from LM76 reduce the surface area where mold and bacteria can thrive, even from the most through sanitizing operations. Long life hybrid stainless steel Si3N4 Silicon Nitride ceramic ball bearings in stainless steel bearing blocks are coated with a smooth non-water absorbing polyamide coating certified by EHEDG, USDA, and 3-A. These FDA/washdown flange bearings employ hybrid stainless steel/ceramic ball bearings that are sealed from contaminates and bacteria via a patented shaft seal system. The seals resist water, cleaning solutions - keeping lubrication from being corrupted and evacuated.
Bearing manufacturer NKE Austria GmbH is entering into a strategic partnership with Kugler Bimetal SA, a Swiss producer of bimetallic components and tribological surface finishes. The cooperation was announced at the Hannover Messe in April 2023.
Welcome back to Part 2 of our inner ring and creep discussion. We left off with our creep calculation resulting in a 10.5 µm minimum inner ring fit to avoid creep. For the sake of making clean dimensions, let’s call it 10 µm on the lower end and the upper end is simply whatever your manufacturer can hold.
PTE will feature a variety of new component technologies online for bearings, motors, couplings, brakes, gear drives, and motion control systems leading up to Hannover Messe 2023 in Germany. Here is a preview of some bearings suppliers to check out if you're planning on attending the event online or in-person in April.
Simplicity linear plain bearings exhibit real benefits, when compared to other styles of linear bearings; such as the self-lubricating quality of the bearing’s Frelon liner, as well as the wiping action on the shaft which enables smooth linear motion.
