NKE Austria GmbH presents its bearings for railway applications. The bearings are used in traction motors and locomotive gearboxes as well as in railcars, trams and underground trains.
SKF has played its part in securing a new world record: the furthest distance travelled by a prototype motorcycle on a single tank of fuel. The prototype bike clocked up 4,183.8 km on its journey from Albino in northern Italy to North Cape in Norway – without needing to refuel. SKF helped motorcycle components supplier Acerbis in its AC50 project to design the two-wheeler.
VesArg, the Argentinian distributor of Vesconite, Vesconite Hilube and Vesconite Superlube low-friction bearing materials, is proud to announce the acceptance of the Vesconite Hilube needle-bearing kit for the Peugeot Partner and Citroen Berlingo, with VesArg having sold 500 kits for these vehicles in the last two years. This innovative solution addresses the recurring problem of suspension arm issues in these popular utility vehicles, which often require replacement needle-roller bearings.
More energy efficiency, higher performance and better controllability are the main reasons why more electric drive systems are being operated with frequency converters. However, these devices can cause high-frequency, asymmetrical interference currents, which, as a current passage through the output and fan-side bearings, can cause damage and premature failure.
Current-compensated CoolBlue toroidal cores made of Magnetec’s nanocrystalline material Nanoperm have proven to be effective protection against such conducted interference and its consequences. In addition, the Nanoperm Line Absorbers NaLA can also be used to significantly suppress symmetrical interference currents.
By definition, a spherical roller bearing (SRB) is a rolling element bearing that permits rotation with low friction and permits angular misalignment. SRBs consist of spherical rolling elements, an outer ring, a cage as well as an inner ring with two raceways inclined at an angle to the bearing axis. SRB technology has landed the component in unique applications including high pressure grinding rolls (HPGRs), pipelaying ships, Ferris wheels and even a Cold War–era marine espionage mission.
NTN is pleased to announce that two of its North American manufacturing facilities have been recognized for supplier quality excellence by Toyota Motor North America (Toyota). Toyota has awarded NTN Driveshaft, Inc., and American NTN Bearing Manufacturing Corporation each with a Certificate of Achievement for receiving an “A” grade for supplier quality in 2022.
With an innovative technology package from SKF, Ningbo Rail Transit has extended the service life of critical refurbished bearings on eight trainset vehicles from 800,000 to 1 million km. The project is the first commercial application of SKF’s Insight Metro wireless condition monitoring system, which has been developed in China specifically for the needs of the domestic rail sector.
Wood and plastic? Is that a good combination? The motion plastics specialist igus has researched the idea in a recent design study and tested the friction and wear behavior of its plastic linear bearings on a wide variety of wood, and the result is impressive. The igus econ J4 plain bearing has demonstrated its exceptional compatibility with various kinds of wood, opening new possibilities for furniture makers and design engineers when choosing materials.
