a successful business.
Michael Odom, certified bearing
specialist and customer sales and service at Applied Industrial Technologies, explains how he used his bearing expertise to save a customer
both money and downtime.
Guy Gendron, certified bearing specialist and technical sales representative at Timken Canada L.P. explains how he used his bearing expertise to increase a customer’s productivity.
In 1991, Needelman and Zaretsky presented a set of empirically
derived equations for bearing fatigue life (adjustment) factors (LFs) as a function of oil filter ratings.
Recently I had a disturbing conversation with a colleague here at the office. During the conversation, it became clear to me that my co-worker -- a really
intelligent guy whom I respect a lot -- had no idea how even the most simple electric motor works.
