It’s as true in pulp and paper as it is in many other industries: the continued rise in energy prices has put a squeeze on margin and profits. Papermakers know that to maintain margin, they must effectively manage their energy costs.
This paper will look at the solutions that current drive and motor technology can offer in not only improving tension control but also solving several other issues that are inherent to systems with high ratio gearing.
The ball screw drive is an assembly that
converts rotary motion to linear motion
and vice versa. The ball screw drive
consists of a ball screw and a ball nut
with recirculating ball bearings...
This article presents the first kW-Class, 3-phase GaN-based inverter. Hard-switched at 100-kHz PWM, its heart is a 6-in-1 power module with 600-V GaN power HEMTs, achieving a new efficiency of 98.5%, a more than 2% improvement.
More than a decade of intensive research and development has resulted in two new technologies that, when used in combination, expand the performance of rolling element bearings well beyond previous limits.
All major manufacturers of 3-phase
AC induction motors offer "inverter-duty" or "inverter-ready” models, but while these motors have inverter-rated insulation to protect the windings, the bearings--their most vulnerable parts--are too often ignored.
