In today's highly competitive world,
the better someone understands the
advantages and benefits of direct drive
technology, then the more they will
have an advantage in machine building,
giving them an edge over their
competition.
Implementing product lifecycle management strategies can be intimidating at first glance, but it's also necessary. Here's why and how you should implement a PLM strategy of your own.
life in this application.
Mechanical guiding systems, such as crossedroller bearings, work well for most motion control applications; however, when precision, angular repeatability, and geometric performance
(runout, straightness) are critical or
where submicron bearing rumble is problematic, air bearings are recommended. An air-bearing stage is a rotary or linear positioner that floats on a cushion of air, using one of several preload mechanisms, nearly
eliminating mechanical contact and thus wear, friction, and hysteresis effects. Here are eight reasons why an air-bearing stage might be the right choice for your application:
Synchronous drives are especially well-suited for low-speed, high-torque applications. Their positive driving nature prevents potential slippage associated with V-belt drives, and even allows significantly greater torque carrying capability. Small pitch synchronous drives operating at speeds of 50 ft/min (0.25 m/s) or less are considered to be low-speed. Care should be taken in the drive selection process as stall and peak torques can sometimes be very high. While intermittent peak torques can often be carried by synchronous drives without special considerations, high cyclic peak torque loading should be carefully reviewed.
The average travel time to
work in the United States is
25.4 minutes, according to
the U.S. Census Bureau. This
number is probably low if you factor in
a traffic accident in New York City, light
rain in Chicago or it's simply Tuesday
in Los Angeles. It's safe to say 25.4
turns into 45 minutes in many areas
of the country at seven o'clock in the
morning.
