| 2024-08-07
Berg Compares Spur and Helical Gears
Mechanical design engineers planning a drivetrain typically have a range of component options to choose from, and many decisions will boil down to the specific application. When it comes to creating optimal torque output, rotational speed and direction, few decisions are as important in designing high performing gear drives as choosing the right gear for the job.
PRODUCT NEWS | 2024-08-06
Portescap Offers Compact Spur Gearing Solution for Pumps
Portescap highlights the B16C gearbox as an ideal solution for optimizing infusion pump designs. This innovative spur gearing solution is tailored for engineers aiming to optimize their infusion pumps without sacrificing performance or reliability. The B16C's compact design reduces the overall length by 3 to 4 mm compared to similar motor/gearbox composites, making it an ideal choice for space-constrained applications.
PRODUCT NEWS | 2020-08-01
The latest product news from Miki Pulley, Voith, Firgelli Automations, Heidenhain, Zero-Max, Gates, KEB America, Siemens, H2W Technologies and Emerson Automation
TECHNICAL ARTICLES | 2020-08-01
FEM Analysis of the Load Distribution over the Face Width of Helical Gear Pairs Considering Deviations, Misalignments and Deformations
The load carrying capacity of spur gears may be calculated by ISO 6336 using influence factors. The face load factor considers the impact of the non-uniform load distribution over the face width. Even if the gears had perfect geometry, the load would not distribute uniformly along the contact lines. The face load factor depends on deformations of all parts of the containing gearbox and mainly of the teeth, gears and shafts as well as on manufacturing and assembly deviations.
| 2020-06-08
TECHNICAL ARTICLES | 2019-03-01
Optimization of Power Density by Local Gear Failure Modeling
| 2018-02-02
EVENTS | 2015-08-01
Calendar
Calendar of upcoming events
TECHNICAL ARTICLES | 2013-12-01
Crowning Spur Teeth - Ask the Expert - December 2013 PTE
When designing spur teeth, is there a formula/guideline/design guide for determining the amount of crowning?
