One of the fun parts of the motion industry is involvement in popular movies! Motor specifications can be a bit rough: "I need to spin a 120-pound actor (and chair) 180 degrees in one-half second. He will be sitting up-right."
Different motor types favor different application areas. No single style has advantages in all application spaces. Direct drive applications favor hybrid servos while high-speed, geared down applications tend to favor the conventional servo motors.
KEB America announces the release of the new STEEL IT epoxy coating for servomotors. When motors are used in applications that are exposed to moisture and chemicals - such as food and beverage processing - they require special design considerations to ensure they will withstand the environment. The new STEEL IT epoxy coating option from KEB America provides a washdown servomotor with many of the benefits of a stainless-steel motor, but at a fraction of the cost.
