Conveying parcel delivery with no system downtime is accomplished with speed and accuracy using Miki Pulley CSZ Clutches. Conveyors continuously operate via servomotor power by way of a V-belt. The system automatically switches on/off as programmed when engaged by the CSZ Clutches.
With the SINAMICS S210 next generation servo drive system, comprising a digitally native drive with wide range of corresponding motors and gearboxes, Siemens brings a new level of high-dynamic, motion control in mid-range operation to stand-alone and multi-axis machines. This next generation servo drive system introduces a new level of safety and security to discontinuous motion control in the mid-range segment, as well as moving, processing and positioning functions on a wide assortment of packaging, printing, labeling, pick-and-place, stacking, assembly, chip sorting and filling machines, with a special emphasis on food-and-beverage and pharmaceutical applications, owing to the availability of stainless-steel motor and planetary gearbox options.
Advanced Motion Controls (AMC) is proud to announce the addition of six new CANopen servo drives with Extended Environment capabilities to their FlexPro line. These new drives join AMC's existing EtherCAT Extended Environment FlexPro drives, making the FlexPro line the go-to solution for motion control applications in harsh environments.
Kollmorgen has announced the new AKD2G 24A drive. Designed for applications in precision multi-axis servo systems, the new single-cable optimized drive builds upon the strengths of the AKD2G portfolio including upgraded safety features, SD card backup and a graphical display with higher amperage to support more applications with higher power requirements such as conveyors and vertical lifting applications.
Kollmorgen has announced ATEX certification and IECEx/cETLus listing for the explosion-proof Goldline EBH 480 Vac servomotor. These new explosion-proof approvals for the high-voltage Goldline EBH servomotor exemplify Kollmorgen’s commitment to advancing the state of the art in motion control and meeting the most demanding application requirements.
Kollmorgen recently announced the launch of Kollmorgen Express Delivery. This new designation identifies highly popular motion products — including some of the most requested configurations and options — that Kollmorgen is ready to deliver within an accelerated timeframe. Machine builders have always benefited from Kollmorgen’s wide range of standard product configurations, features and options. This broad portfolio serves the unique needs of many diverse industries and applications but can create challenges for rapid delivery, especially when material supplies are constrained.
