Mitsubishi Electric Corporation recently announced that it had been awarded a Guinness World Records title on May 21, 2024, for the fastest robot to solve a puzzle cube using the TOKUI Fast Accurate Synchronized Motion Testing Robot (TOKUFASTbot). The previous record of 0.38 seconds was trumped by TOKUFASTbot's time of 0.305 seconds.
Measure angles or move to a precise angular position with a new series of high precision, low cost XYHG Multi-axis Stages that can be easily integrated into new and existing applications from OES (Optimal Engineering Systems).
The miniature GVCM-019-032-02 Linear Voice Coil Servo Motor has been released by Moticont. It is only three-quarters of an inch (19.0 mm) in diameter and features a 0.875 in. (22.2 mm) stroke. Also called an electric cylinder, this miniature linear servomotor, features a continuous high-force-to-size ratio of 7.4 ounces (2.1 N) and 23.3 ounces (6.5 N) of peak force at a 10 percent duty cycle.
Servo Technology has gone through various key stages of evolution, from the Power Transistors (Servo 1.0) and DSP/Microprocessor (Servo 2.0) to the Integrated Packaging (Servo 3.0) and Industrial Network (Servo 4.0). We are now entering the new era in servo evolution called Servo 5.0, where the intelligence and connectivity, in align with the emerging Industry 4.0 effort, are now required in the traditional servo control products.
The Factory Automation (FA) Integrated Selection Tool allows customers to plan and configure their Mitsubishi Electric machines, resulting in a downloadable Bill of Materials (BOM).
Moticont has released the GVCM-022-013-01 Linear Voice Coil Servomotor. This compact .875 in. (22.2 mm) diameter high speed, high force-to-size linear motor features high accuracy and high repeatability when operated in a closed loop as a DC servo motor. This brushless servo motor is clean, quiet and has long life, low mass and high acceleration/deceleration for high throughput.
The 2023 SPS trade fair in Nuremberg represented an important opportunity for Bonfiglioli to showcase its experience and expertise for industrial automation. This included mechatronic solutions specifically designed for packaging, intralogistics, robotics and IoT applications.
