Equipment downtime and reduced component
life are a few of the consequences — and
potential costs — of using the wrong seals on many types of industrial equipment including pump bearing frames, electric motors, fans, pillow blocks, gearboxes and more. However, if
correctly specified and installed, seals provide effective barriers that both retain lubricants as well as protect against water, corrosion, debris and other contaminants.
conveying system on the varnishing
line for a manufacturer of high-end
kitchen cabinets were leaking. Oil was
dripping on the cabinet parts — ruining
the finish. Why were half of the
gearboxes leaking?
Without the sun, there would be no
Earth and no life. However, our knowledge about our home star is still very limited. This is about to change. In 2018, the European Space Agency (ESA) will send its Solar Orbiter into space, equipped with a thick heat
shield.
finished products.
For either brand-new motors or those already in service, "best practices" means that informed technicians can make use of the latest diagnostic techniques (vibration analysis, thermography, shaft-voltage testing, etc.) to prevent electrical bearing damage -- either at the very beginning or very quickly thereafter. If done correctly, the work need only be done once.
