Asymmetric tooth gears and their rating are not described by existing gear design standards. Presented is a rating approach for asymmetric tooth gears by their bending and contact stress levels, in comparison with symmetric tooth gears, whose rating are defined by standards. This approach applies finite element analysis (FEA) for bending stress definition and the Hertzian equation for contact stress definition. It defines equivalency factors for
practical asymmetric tooth gear design and rating. This paper illustrates the rating of asymmetric tooth gears with
numerical examples.
