If torque conversion with high gear ratio, compact installation space and 90-degree axis-crossing angle is needed, often worm gears are used. Due to their high power density and sliding speeds within the tooth contact, frictional heat and thermal stresses are higher compared to helical, bevel and hypoid gears, and thus the thermal load capacity of worm gears is lower.
The load carrying capacity of spur gears may be calculated by ISO 6336 using influence factors. The face load factor considers the impact of the non-uniform load distribution over the face width. Even if the gears had perfect geometry, the load would not distribute uniformly along the contact lines. The face load factor depends on deformations of all parts of the containing gearbox and mainly of the teeth, gears and shafts as well as on manufacturing and assembly deviations.
