China is leading the world in the construction of solar, wind and thermal power plants to support its increasing demand for electrical energy. For those that use steam turbines, boiler feed pumps (BFPs) are a crucial asset and selecting the best design to suit the needs of an individual station can have many benefits. When a recent project needed some of the largest start-up BFPs available, Sulzer was selected as the preferred supplier.
A calculation platform suitable for all areas of gearbox development
December 1, 2023
Developing a new gearbox series is costly and time-consuming. This is especially true in marine propulsion, as classification society certifications must be achieved in addition to the required verifications. For this reason, Reintjes offers the same drives for various types of ships. In gearbox development, this means that each application requires different loads and usage profiles, with different service lives and maintenance intervals. Thus, each drive must be designed and calculated with advance consideration of every possible profile.
The 2023 SPS trade fair in Nuremberg represented an important opportunity for Bonfiglioli to showcase its experience and expertise for industrial automation. This included mechatronic solutions specifically designed for packaging, intralogistics, robotics and IoT applications.
This report derives the equation for relative elastohydrodynamic lubrication (EHL) film thickness. Mineral (MIN), polyalphaolefin (PAO), and polyalkylene glycol (PAG) lubricants with viscosity grades of ISO 320, 150, and 32 are analyzed.
More energy efficiency, higher performance and better controllability are the main reasons why more electric drive systems are being operated with frequency converters. However, these devices can cause high-frequency, asymmetrical interference currents, which, as a current passage through the output and fan-side bearings, can cause damage and premature failure.
Current-compensated CoolBlue toroidal cores made of Magnetec’s nanocrystalline material Nanoperm have proven to be effective protection against such conducted interference and its consequences. In addition, the Nanoperm Line Absorbers NaLA can also be used to significantly suppress symmetrical interference currents.
From manufacturing to maritime, the quest for sustainable solutions has given rise to the development of environmentally friendly lubricants. Among these, Environmentally Considerate Lubricants (ECL) and Environmentally Acceptable Lubricants (EALs) have gained prominence for their positive impact on both equipment performance and the planet. Let’s delve into the differences and advantages of these lubricant classifications.
