With the increasing mechanical power capacity of gearboxes, the thermal power limit tends to become the limiting factor. To achieve a balanced system, the gear unit needs extra cooling. Using a fan that is mounted to a fast rotating shaft is a common solution. For this solution an optimal design is investigated.
Improving System Performance One Application at a Time. PTE recently caught up with IKO, Rollon and THK to breakdown the basics in linear motion rolling guides.
Approximately one quarter of all servo motors around the world require some type of gear reduction in their applications. From large satellite dishes to precision medical devices, gearboxes boost torque and reduce speed for servos in order for them to be sized
more efficiently. While gearbox fundamentals haven't changed much over the past 20 years, their effectiveness has improved significantly, driven mostly by the need to accommodate advancements in servo technology.
