JIE USA has released a 3D CAD gearbox and gearmotor configurator to help engineers choose motors and drives on-demand. The online tool enables engineers to identify the correct product for their design or application based on custom parameters and deliver the CAD model or PDF datasheet they need to do their job efficiently.
One of ONYX’s customers and a leader in driving up the reliability and asset performance of the wind industry, Pattern Energy, uses ONYX turbine monitoring for over 1,100 wind turbines. Across this fleet ONYX connects several CMS hardware types to fleetMONITOR, a multi-brand solution for drivetrain monitoring. Two of the wind farms were retrofitted with ecoCMS in 2018, the technology with which ONYX disrupted the CMS industry.
Warner Electric has developed custom brake friction material that provides consistent performance despite extreme temperature variance and the effects of moisture.
SKF has developed a new range of adjustable chocks with higher load capacity and an increased adjustment range. The chocks can be used in many industries, including food and beverage, pulp and paper, rail, marine, offshore, agriculture and power generation. They are typically found in equipment such as gas, diesel and LNG engines, generators, compressors, electric motors and gearboxes.
