Providing production flexibility in machinery design, to manufacture or process different product sizes for example, is becoming more of a necessity with todays desire for shorter runs and quicker deliveries. See how we helped a customer, with some of our unique capabilities, achieve the flexibility they needed.
With the increasing mechanical power capacity of gearboxes, the thermal power limit tends to become the limiting factor. To achieve a balanced system, the gear unit needs extra cooling. Using a fan that is mounted to a fast rotating shaft is a common solution. For this solution an optimal design is investigated.
This issue, we're pleased to present our annual Buyers Guide. It's our comprehensive directory of suppliers of mechanical components, including gears, bearings, motors, couplings, clutches, brakes, gear drives and more.
Spiroid's skew-axis, high torque gears enable world-class power density. Custom reduction gearboxes can meet your application's needs. Does your application call for small right angle gearing that packs a big punch? Spiroid & Helicon Gearing:
