By Jerome Jennings, global product manager, SPX Cooling Technologies, Inc.
Industries that require process heat rejection often use field-erected cooling towers to keep pace with their heat load. Cooling towers have large fans and powerful motors, which can present a host of challenges, including excessive sound, vibration and expense. Gearboxes are employed to address these challenges.
Gearboxes are important assemblies within mechatronic systems. During the design phase of such systems it is essential to know the gearbox behavior under consideration of dynamic interactions with its environment. Holistic system simulation helps the engineer to understand this and to improve, adjust, or optimize gearboxes and their application.
Modern drivetrains with voltage-source inverters not only offer advantages like, for example, variable speed operation, increased efficiency and higher dynamics, but also an increase in failures caused by induced parasitic currents.
After decades of iteration, you might think manufacturing software suites are running out of new modules to add, but improving hardware is opening up new avenues for them to explore.
Many refineries and chemical plants are built with large pieces of rotating equipment in an outdoor setting exposed to the elements. The author has been researching thermal growth issues for decades across North America.
A big trade show can be extremely overwhelming. There are so many important suppliers to talk to, it's often hard to know even where to start, let alone how to plan a strategy to maximize your time spent.
The MSR 2-Speed VTL turntable is a new technology that combines two right angle, 2-speed gearboxes to perform high power turning and precise C-Axis motion for milling.
It is a compact system that dramatically simplifies VTL turntable kinematics and insures high performance with respect to speed range, torque and accuracy.
Andantex USA Inc.
