Here at Precision Pump and Gear Works we offer emergency Gearbox service available 24/7, and have free pickup and delivery across the states. We rebuild gearboxes for the following industries: recycling, mining, marine, pharmaceutical, chemical, power plants, oil field, steel mills, and the food industries, plus more. Precision Pump and Gear Works does not shy away from a challenge in fact we welcome it; we will rebuild gears that are broken, chipped, or the teeth have been worn down over time.
R+W has released the CHB housing for parallel assemblies of motors and actuators. Each unit is machined to order and fits the motor / gearbox and actuator mounting patterns. Multiple ratios are available and a keyless clamping system inside ensures smooth operation even during reversals. Find out more about this compact mounting solution.
