The AWS-TF Series of bearings was designed expressly for wind turbine gearbox applications, achieving up to 7 times the life of standard bearings in hydrogen-charged environments. That means dramatically extended service intervals, increased efficiency and lower operating cost.
Isomag magnetic bearing isolators use superior face seal technology to protect the bearings on thousands of centrifugal machinery including but not limited to: pumps, gearboxes, electric motors, steam turbines, and blowers. The lapped flat faces create a positive liquid tight seal preventing lubricant leakage and the ingress of contaminants.
In planetary gear systems of high power density and high gear ratio, helical gears create undesirable tilting moments on the planet gears; therefore, spur gears are still preferred for planetary gears -- a special challenge with respect to noise. Specifically, the different behavior of planetary gears with sequential and symmetric gear mesh is explained in this paper.
