Andantex USA’s objective over the years has always remained the same: to provide innovative, high-quality gearboxes and solutions for use on industrial machinery. The Anglgear right angle drive is an example of our commitment to our customers’ needs and applications.
Rolls-Royce is pioneering the UltraFan engine family architecture containing a planetary gearbox in a power range of 15 to 80 megawatts. To increase the efficiency of the UltraFan, a planetary gearbox is introduced between fan and intermediate pressure compressor. This enables running the turbine to rotate faster and allows a reduced fan speed.
The load carrying capacity of spur gears may be calculated by ISO 6336 using influence factors. The face load factor considers the impact of the non-uniform load distribution over the face width. Even if the gears had perfect geometry, the load would not distribute uniformly along the contact lines. The face load factor depends on deformations of all parts of the containing gearbox and mainly of the teeth, gears and shafts as well as on manufacturing and assembly deviations.
The AWS-TF Series of bearings was designed expressly for wind turbine gearbox applications, achieving up to 7 times the life of standard bearings in hydrogen-charged environments. That means dramatically extended service intervals, increased efficiency and lower operating cost.
Isomag magnetic bearing isolators use superior face seal technology to protect the bearings on thousands of centrifugal machinery including but not limited to: pumps, gearboxes, electric motors, steam turbines, and blowers. The lapped flat faces create a positive liquid tight seal preventing lubricant leakage and the ingress of contaminants.
