With more models, sizes, and ratios, DieQua's spiral bevel gearboxes offer precision, performance and durability far above standard products. They're ideal for applications requiring high speed, precise motion control, high torque, or heavy shocks. Several configurations, options, and customized solutions provide unmatched design versatility.
NSKHPS cylindrical roller bearings are engineered to deliver extended high performance with the high loads and speeds of modern industrial gearbox applications. Optimized materials, cage designs and lubricant flow results in low-noise running with reduced heat generation.
EVOX is a helical in-line gearbox designed with a smooth surface that can be adapted to any machine. The new asynchronous low voltage e-motor was developed with modularity, efficiency and reliability in mind. They’re the answer to tech complexity market demand and are compliant with the strictest energy efficiency standards.
