Gear drives deliver power to industrial
equipment such as bulk material
conveyors, mixers, pumps and paper
mills. The reliability that translates into greater uptime and profitability begins by specifying and selecting the proper drives for these critical applications.
Even when the critical components of industrial power transmission gear drive systems are properly designed, specified
and manufactured consistent with application requirements, performance
problems can develop over time and failure may follow.
All major manufacturers of 3-phase
AC induction motors offer "inverter-duty" or "inverter-ready” models, but while these motors have inverter-rated insulation to protect the windings, the bearings--their most vulnerable parts--are too often ignored.
In most cases, industrial power transmission calls for flexible rather than rigid couplings in order to forgive minor shaft misalignment. For that reason, this article will focus solely on the selection of flexible couplings.
