All major manufacturers of 3-phase
AC induction motors offer "inverter-duty" or "inverter-ready” models, but while these motors have inverter-rated insulation to protect the windings, the bearings--their most vulnerable parts--are too often ignored.
In most cases, industrial power transmission calls for flexible rather than rigid couplings in order to forgive minor shaft misalignment. For that reason, this article will focus solely on the selection of flexible couplings.
Fairchild International, a U.S.-based manufacturer of underground mining equipment, has produced battery-powered DC scoops since the early 1980s. With 17 different models available, Fairchild offers a size to fit any coal mining operation, making it the leader in the industry.
At a Midwestern producer of tubular
steel products, measures taken to counteract the effects of impact on a quench tank roll made it difficult to remove and replace the conventional pillow block bearings that support the roll’s shaft.
A new preventive maintenance program at a leading New England Ivy League university demonstrates how the push
for more sustainable "green" building management has led to a growing awareness of a chronic, widespread problem with HVAC motors—electrical bearing damage and failure.
Compact loaders are employed where large machines have no access or are over dimensioned. New hydrostatic drives from ZF meet the demanding needs of this market.
