Ruland Manufacturing now offers bellows and double disc couplings with bore sizes up to 1-3/4 in or 45 mm for use in systems with torque up to 1,4000 in-lbs. (158 Nm). High torque applications commonly found in precision semiconductor, solar, conveyor, and factory automation applications often use these shaft sizes. Ruland disc and bellows couplings accommodate all forms of misalignment, are zero-backlash, and have a balanced design for reduced vibration at speeds up to 10,000 rpm.
There is no compromise to safety in robotic applications. Lightweight robots or collaborative robots (cobots) are capable of complex and unexpected movements and need to stop immediately ensuring the safety of human operators. This is where smart couplings and smart brakes provide intelligent flexibility and guidance.
Gates announces the launch of the Clean Master Plus hose platform, the newest addition to Gates’ industrial hose lineup, built for high pressure applications in demanding industrial environments.
Ruland Manufacturing now offers rigid couplings with inch-to-metric bores as a standard product, giving users a wider range of off-the-shelf couplings. This expansion is the latest addition to the company's inch-to-metric, standard coupling product line that includes seven types of motion-control couplings and universal joints. Instead of re-machining or ordering custom-made couplings, using off-the-shelf, inch-to-metric rigid couplings saves time and money.
Corrosive chemicals such as chlorine, acids, alkalis and solvents require special pumps to handle their corrosive properties. Centrifugal pumps are most often used and offer advantages during the production process particularly when operating with Stainless Steel ASK Couplings from Miki Pulley.
Motion Industries, Inc. recently named
Chris Cleland to senior vice president of strategy and markets, effective immediately.
Cleland’s career spans over 25 years in consulting,
strategy, marketing, branding, e-commerce, business
development, and transformation.
Shaft collars and mounts that can be adjusted without tools, plus handles
and thumb screws to convert standard shaft collars to quick-adjust types,
have been introduced by Stafford Manufacturing Corp. of Wilmington, MA.
Stafford Quick-Adjust Products feature the Flip-Lok with a split hub and
an integral adjustable clamp, Staff-Lok Lever-Actuated shaft collar, and
the Python Flange Mounting Collar with a 6-hole bolt pattern and keyway.
Suitable for a wide range of linear and low RPM rotary applications, these
quick-adjust products can be easily repositioned by hand without tools.
