Motion Industries, Inc. recently named
Chris Cleland to senior vice president of strategy and markets, effective immediately.
Cleland’s career spans over 25 years in consulting,
strategy, marketing, branding, e-commerce, business
development, and transformation.
Shaft collars and mounts that can be adjusted without tools, plus handles
and thumb screws to convert standard shaft collars to quick-adjust types,
have been introduced by Stafford Manufacturing Corp. of Wilmington, MA.
Stafford Quick-Adjust Products feature the Flip-Lok with a split hub and
an integral adjustable clamp, Staff-Lok Lever-Actuated shaft collar, and
the Python Flange Mounting Collar with a 6-hole bolt pattern and keyway.
Suitable for a wide range of linear and low RPM rotary applications, these
quick-adjust products can be easily repositioned by hand without tools.
Drive specialist Flender has received the Supplier Excellence Recognition Award 2023 from U.S. machinery manufacturer Caterpillar. Flender received the award for maintaining 95 percent delivery
reliability and zero defects. This achievement is awarded only to the top suppliers of Caterpillar. It
positions Flender as a top supplier for its global Aftermarket (Reman) Division business.
Bega Special Tools introduces a portable multi-purpose induction heater on the North American market. The MF Quick-Heater 3.0-3.5 kW can be used for mounting, dismounting and pre-heating purposes. Weighing less than 8 kg and fitting in a small carrying case, this easy-to-use but powerful tool is just plugged into the mains 230 V. It can be used in difficult circumstances where other systems are impossible to operate, for instance where there is little space to work in or where no open fire is permitted. The heater’s flexible inductors are ideal for a large variety of parts with a maximum diameter of 120 mm. Application examples can be found in all types of industries.
Ruland zero-backlash jaw couplings are a three-piece assembly designed to accommodate high acceleration and deceleration curves that result in peak torque. Jaw couplings are ideal for systems that experience hard starts, hard stops, or reversals, including in medical, semiconductor, test and measurement, and robotics applications.
The Dune Express is a 42-mile long, fully electric conveyor system that is expected to transform the Permian Basin and substantially improve the unacceptable safety risk existing on the Permian roadways. Originating from the Kermit, Texas facility and spanning into New Mexico, the Dune Express is intended to eliminate millions of truck miles driven across the Permian resulting in avoided traffic, accidents, injuries, and fatalities within the communities.
Voith Turbo North America has broken ground on a $5 million expansion of its workshop in York, Pa. The expansion will increase the Group Division’s American manufacturing capabilities.
Atlas Energy Solutions has selected Voith Turbo to supply a total of 21 TurboBelt 800 TPXL fill control fluid coupling drives (including spares) to power 42 miles of conveyor belt as part of Atlas Energy Solutions’ historic Dune Express project. ELIN Motoren, a Voith company, will also provide 21 customized low noise electric motors for the project, including spares. Once in operation, the overland conveyor system will serve as a low-impact transport system, taking sand from Texas to New Mexico while establishing a new world record for a single conveyor flight without a mid-belt drive at an impressive 16.3 miles overall single flight length.
TPS, still organized by the Turbomachinery Laboratory at Texas A&M University, will gather for the 52nd Turbomachinery and 39th Turbo annual event from September 26–28, at the George R. Brown Convention Center in Houston.
Nord’s newly improved NEMA and IEC input adapters offer improved mechanical and thermal performance, giving users more flexibility in designing drive systems and allowing for a broader range of application and environment-specific concepts through extended options such as integrated backstops and speed sensors. The redesigned input adapters are available NEMA sizes 250TC – 400TC and from IEC sizes 160 – 315
