Mounted ball bearings are everywhere in industrial applications. They serve critical roles in keeping a manufacturing operation running smoothly and in ensuring that equipment functions properly and reliably. So why might it be advisable to spend significantly more for a dimensionally
comparable bearing from one supplier versus another?
For the most accurate measurements,
miniature and instrument ball bearing
dimensions should be measured with a
calibrated air gauge. A good second option is a calibrated optical comparator. On occasion, it may be necessary to use a calibrated, hand-held micrometer to double-check a measurement or for simple verification while working in the field.
More than 27,000 packaging and processing professionals attended Pack Expo 2013 in Las Vegas from September
23–25. In addition to launching new products, creating brand awareness,
achieving sustainability goals and generating new business contacts, Pack Expo was an opportunity to engage the next generation of workers in packaging, robotics and processing
applications.
Implementing a predictive maintenance
(PM) program can be tough. Despite its proven success, many companies have been operating the same way for over 50 years and don’t know where to start. Understanding where to start and where to focus is critical. The intention of this article is to give insight to start and sustain an effective program using today’s technology and devices.
