A new solution has been developed around
the use of microprocessor-controlled
prostheses. Just like natural limbs, these
can react automatically, adapting to the
current situation.
This article takes a look at alternative-material, non-metal bearings, and it turns out the first bearings of that type - wood, in this case, were the
norm - not an alternative.
Based on simulation methods and calculation tools developed by the Schaeffler Group and presented in the first part of this paper, three approaches regarding increased efficiency based on rolling bearings are presented.
