Recently I had a disturbing conversation with a colleague here at the office. During the conversation, it became clear to me that my co-worker -- a really
intelligent guy whom I respect a lot -- had no idea how even the most simple electric motor works.
Mounted ball bearings are everywhere in industrial applications. They serve critical roles in keeping a manufacturing operation running smoothly and in ensuring that equipment functions properly and reliably. So why might it be advisable to spend significantly more for a dimensionally
comparable bearing from one supplier versus another?
For the most accurate measurements,
miniature and instrument ball bearing
dimensions should be measured with a
calibrated air gauge. A good second option is a calibrated optical comparator. On occasion, it may be necessary to use a calibrated, hand-held micrometer to double-check a measurement or for simple verification while working in the field.
The history of railroading is a saga of epic proportions: North meets South; Ocean meets Ocean. Track and trains and the locomotives that power them have long held Americans' fascination and fancy.
At first glance, ball bearings are
relatively simple mechanisms. However,
an analysis of their internal geometries
reveals that they are quite complex. For
example, the ball to raceway conformity,
the radial play, and the number of balls all impact the ability of a ball
bearing to support loads under a variety
of conditions.
