In order to analyze the different gear
oils suitable for the lubrication of wind turbine gearboxes, five fully formulated ISO VG 320 gear oils were selected. In between the selected gear oils, four PAO base oils can be found: PAOR, PAOM, PAOC and PAOX. A mineral-based oil (MINR) was also included as reference.
Wind is a form of solar energy.
Winds are caused by the uneven heating
of the atmosphere by the sun, the
irregularities of the earth’s surface, and rotation of the earth. Wind Turbines
convert the kinetic energy in wind into
mechanical power.
Richard (RJ) Seguin, CBS and technical
sales representative at AMI Bearings,
explains how his bearing expertise tripled
the life of a customer’s bearings.
