Manufacturing Medical Packaging Bearings Motors Sensors Product News Assembly
MSS Offers Rotary Solenoids Series
The R-09-150 CWN Series of Clockwise, Reverse Shaft Extension Rotary Solenoids from Magnetic Sensor Systems (MSS), available in OEM quantities, features 18 different winding configurations allowing the user to match torque and duty cycle requirements to an application. These compact 38.1 mm (1.50 in.) diameter solenoids are just 22.1 mm (0.87 in.) long and have two M4X0.7 threaded studs (8-32 studs optional) 7.4 mm (0.29 in.) long on a 22.2 mm (0.875 in.) bolt circle.  The reverse shaft has 40 degrees of clockwise rotation, extending 13.0 mm (0.51 in.).  Shaft end is serrated for better grip of the attached load.
The R-09-150 CCWM Series of Rotary Solenoids can be specified with a choice of AWG winding of 21 to 37 gauge.    Specifying a different AWG for the windings allows the user to control the performance of a solenoid with respect to duty cycle, current supplied, and torque by controlling the ampere turns.  As an example: Starting torque of a solenoid at 9 w, 100 percent duty cycle, is 3.0 oz-in. (0.021 Nm) and start torque of a solenoid at 90 w, 10 percent duty cycle is 21 oz-in. 0.15 Nm).  When voltage is removed, a built-in return spring returns the shaft to the home position.
The shaft is supported by two high precision radial ball bearings with no axial movement.
Low cost, the R-09-150 CWN Series of Rotary Solenoids feature long life, clean and quiet operation are ideal for: Office machines, security mechanisms (interlocks), medical devices, assembly, sorting, clamping, packaging, shutter actuation, vending, and games.
