Matthew Jaster, Senior Editor
It’s hardly a stretch of the imagination to walk into the SKF Product Investigation Center (42 miles northwest of Chicago) and think about a crime lab. Though the employees here have titles like material development engineer, investigation administrator or application engineer, they’re all detectives in the grand scheme of things. Instead of solving crimes, they’re tasked with determining why seals fail. They take this data and share it throughout SKF in order to make their products safer and more efficient. It’s also a pivotal step in developing new seal technologies.
Bryan Uncapher, seal business development at SKF, says that most rotating equipment will work until bearing failure, which is greatly related to seal performance. “If it is a grease application, external contamination can enter the bearing and cause corrosion or wear, which will lead to system failure or stoppage. If oil is the main lubrication, the oil will eventually leak out, which causes metal to metal contact, which also leads to bearing failure. This can result in a great amount of repair and loss performance expense for the operator,” he said.
The investigation center was created to determine the root cause of rotating equipment failure, analyze how the seal reacts under certain environmental conditions and build a database (or backlog) to classify typical failures for future reference. Here, in a maze of testing stations, analytical labs and manufacturing work cells, the former Chicago Rawhide headquarters (see sidebar) has the look and feel of a highly-technical research center where seal failure is literally put under the microscope.
Seals have a crucial impact on system performance. They need to provide a minimum amount of friction and wear while maintaining maximum protection from external environmental contamination and retain bearing lubrication under a variety of unique and hazardous conditions. When they fail, machines, operators and components are all at risk.
The SKF Product Investigation Center has a very thorough (and organized) procedure to examine each seal case.
“The advantage of our new product investigation system is that it offers a systematic approach to define the root cause of failure and identify possible solutions. It ensures that our application engineers can collect the critical field data and work according to a scientific process with our analytical, chemical and validation labs to identity the causes of failure and offer the right solution for our customers,” said Bouchra Le Hir, global product testing & investigation manager at SKF.
So, what exactly happens when a customer sends a seal into the investigation center? First, it’s the job of application engineers like Mark Haughey to examine the seals, collect all the pertinent information (any damage analysis, application history, etc.), conduct initial inspections and report key findings.
This includes examining the packaging materials the seal was shipped in as well as checking for any contaminations. The engineers will also look to see if the damage was simply a case where the operator dropped the seal on the floor prior to installation (which happens more than you think).
Most of this initial research is considered a Level 0 investigation.
A Level 1 investigation includes taking photos of the seal (courtesy of a light box assembly created by Philip Sajor), and an initial comprehensive bearing seal inspection. Dave Zimmerman, investigation manager, is one of the first in the building to provide this detailed inspection.
Zimmerman begins with a small pile of plastic bags at his workstation. These bags hold various seals from industries like automotive, off-highway equipment, steel mills, rail, and mining applications (to name a few). Each seal tells a different story and provides Zimmerman with clues as to why the seal failed in the first place. There are several different causes of seal failure including manufacturing defects, assembly errors, compatibility with the lubrication or working fluid, and/or system design flaws.
Seal failure can sometimes be determined by simply taking the seal out of the plastic bag and examining it with the naked eye. Other cases might need a combination of microscopes, photographic images, hand tools and 38 years of bearing seal experience to help solve the mystery. Zimmerman has all four.
A seal customer may submit a performance claim (citing the seal product itself as the cause of failure) on many seals that come across Zimmerman’s desk even though it shows obvious signs that it was damaged by the installer.
Zimmerman said one of the most common modes of failure is improper installation, where the seal case is hit with a metal socket which changes contact forces, backward installation, misalignment, and cut lips. What is very interesting is that operation errors are one of the easiest methods to detect if samples are provided.
If that’s still not enough, the seal moves to Sajor and the SKF measurement team in a temperature-controlled room for a variety of evaluations. Then it is moved to the next levels of inspection (Level 2: the analytical lab with Albrecht Becker) and (Level 3: Terry Kirschbaum, test lab validation).
Once you get into Level 2 and Level 3, the seal is put through a series of intense chemical and environmental tests for further analysis. It truly is a team-based process where the slightest errors or miscommunication could hinder the outcome.
“We’re in constant contact with everyone involved in a particular investigation,” Kirschbaum said. “You have to have all the information in front of you in order to succeed and this information needs to be as accurate as possible. Communication is so important, it might be as simple as making sure metric and inch conversions are consistent.”
These investigations come with a laundry list of challenges, according to Uncapher, though meeting these challenges is part of what makes the investigative work so interesting.
“Sometimes determining the mode of seal failure is difficult when limited information is supplied, as it is critical to know the hours of operation, application temperature from oil and environment (min & max), operating speed, age of product installed being able to distinguish between damage from seal removal versus application issues and manufacturing defects,” he said. “Also, when working with rubber seals it can be difficult to differentiate from manufacturing defects (process contamination and mishandling) versus application impact.”
The key is having the right amount of experience and the right equipment to do the job.
“SKF meets these various challenges with equipment for visual inspection (microscopes), CMM dimensional measuring, and chemical analysis tools (FT-IR Fourier transform infrared spectroscopy and X-ray fluorescence), thermal analysis (thermal gravimetric analysis, and DSC Differential scanning calorimetry) and physical analysis tools (hardness, tension, compression, wear and fatigue testers),” Le Hir said.
The obvious benefit of product investigation is for SKF to develop a positive working relationship with its customer base. By providing quick, efficient solutions for their manufacturing challenges, they will continue to utilize SKF products and services in the future.
“We’re working first and foremost for our customers,” said Uncapher. “But there is plenty of research and analysis conducted here that benefits us internally as well.”
Often, a customer will make upgrades to their machines including new additives to their lubrication, more horsepower, faster speeds and higher pressures and temperatures. “There are many cases where the customer fails to check with the seal manufacturer. Having the ability to understand the cause of failure and product limitations allows us to develop new seal configurations in the future,” Uncapher said.
And this is why the work conducted here is so vital, according to Le Hir. “Each case involves a learning curve. We’re taking this field research and applying it to future products that will make them better. It’s an educational opportunity for our staff as well as our customers.”
For example, Zimmerman discussed earlier that one of the most common modes of failure is improper installation. As a result, SKF has developed a line of installation tools for its Scot Seal Products to increase the robustness of the supporting structure and allow for easier installation in latter generations.
SKF is also currently working on the project to collect all typical failures and classify them, and at the same time develop a user-friendly mobile application. “This will be beneficial for our customers for understanding our investigations and visualizing the scenarios of failures,” Uncapher said.
One of the challenges mentioned regarding seal investigation was the lack of information available on the entire mechanical system. In many circumstances, the application engineer is working with very a limited amount of data and in most cases just the seal itself which begs a different question: Would it benefit the investigation center to look at the entire system and not just the seals?
Uncapher said that SKF would need a much larger receiving and tear down area as a bearing and seal might be part of large and heavy system. “We are able to measure and inspect up to 2.5 tons in Elgin and have other facilities in SKF which can accept much large items, but normally this is prohibited given the transportation costs and asset value. Additionally, we are able to perform level 0 & 1 inspections for bearings.”
He continues, “Very often customers do not have spare housing and shafts and must reassemble new bearings and seals and continue production. This is why we rely on our field support team of application engineers and industrial specialists to collect the critical field data.”
The plan in Elgin is to further implement computer simulation and modeling for seals. The investigation center and test lab allow for validation of existing models and creation of new modeling formulas. “We are planning to add a microscope with advanced features and also a Scanning Electron Microscope (SEM) to go in-depth in the investigations and analysis,” Le Hir said. “Currently, we’re using an SEM located in another SKF facility.”
Without doubt, the success of the investigation team in Elgin will rest on the capable shoulders of the women and men behind the scenes, testing products, analyzing materials and providing data that can be used to make seal products and technologies better and more reliable in the future.
“It is very difficult to find experts in this field since it is not something that can solely come from education, but it is more of combination of higher education and years of experience,” Le Hir added. “The more experts we have with investigation experience, the closer we get to the root cause of failures and can implement the corrective action.”
For more information:
SKF Sealing Solutions
900 N State Street, Elgin, IL
Phone: (847) 742-7840
www.skfusa.com
During the Great Chicago Fire (1871) every establishment working with leather in the city of Chicago was destroyed. In the next few years, Chicago moved very rapidly to “Rise up Again” from the disaster.
Seven years after the Chicago Fire, in 1878, three men, William H. Preble (secretary), August C. Krueger (leather processor) and Andrew Spurling (president) met in a loft near Monroe and Clark in Chicago, hired 25 employees and began the manufacture and sale of rawhide products under the name of Chicago Rawhide Manufacturing Company.
The main purpose of the company filed in the incorporation papers in 1879 was the “purchase and curing of hides, the manufacture and sale of rawhide leather, belting, lacing, ropes and all other articles of merchandise and utilities where rawhide leather can be used.”
In 1882, William H. Emory, a banker, proposed to build for the original owners a building to manufacturer these products on Ohio Street in Chicago. By this time, the company was making rawhide fly nets for horses, rawhide ropes, rawhide shoe laces, leather belting and buggy whips.
Leather belting around steam engines and pulleys (in the late 1880s) was now driving the U.S. Industrial Revolution. In 1891, Emory was elected president of Chicago Rawhide and the company was the only manufacturer of rawhide belting in the world.
Matthew Jaster, Senior Editor, has a B.A. in journalism from Columbia College Chicago and has 15+ years of writing and editing experience in automotive, manufacturing, engineering, law and arts and entertainment.
