Food & Beverage Material Handling Motion Control Packaging Linear Motion Motors Product News Motor Design Motor Efficiency Agriculture
Dunkermotoren Launches Linear Motor Series
It does not matter if this motor is used under the strictest hygienic requirements in the food sector, in industrial production, or in the harsh environment of agricultural technology - the SL 38 STL is the perfect partner in terms of power and speed. With peak forces of 3700N and accelerations of over 200 m/s2, it can raise the system´s throughput to a new level, and with maximum precision.
Thanks to the sophisticated drive design with smooth surfaces, special screw connections, and stronger seals, the stainless-steel housing enables IP protection up to IP69K and thus guarantees exceptional resistance against environmental impacts. This ensures simple and thorough high-pressure cleaning as well as high corrosion resistance despite frequent contact with disinfectants and detergents.
High forces, precision, and IP classes make the SL 38 STL an allrounder for packaging, filling and handling systems in the industrial, agricultural and food sectors.
dunkermotoren.com/en/contact-us
This article appeared in the March 2024 issue.
