Vesconite Utilizes Needle Bearing Kit for Suspension Arm Issues
VesArg, the Argentinian distributor of Vesconite, Vesconite Hilube and Vesconite Superlube low-friction bearing materials, is proud to announce the acceptance of the Vesconite Hilube needle-bearing kit for the Peugeot Partner and Citroen Berlingo, with VesArg having sold 500 kits for these vehicles in the last two years. This innovative solution addresses the recurring problem of suspension arm issues in these popular utility vehicles, which often require replacement needle-roller bearings.
Utility vehicle owners often encounter frequent mechanical service requirements due to the unsuitability of traditional needle-roller bearings for applications exposed to water and abrasive contaminants. These recurring problems have long been a source of frustration for vehicle owners and mechanics alike.
The Vesconite Hilube needle-bearing kit offers a professional and durable solution with Vesconite Hilube self-lubricating bushings. Designed to withstand the rigors of daily use, each kit is engineered to support up to 7,500 kg per arm, ensuring a significantly extended service life under optimal operating conditions.
Each Vesconite Hilube needle-bearing kit for Peugeot Partner and Citroen Berlingo vehicles includes the following components:
• two Vesconite Hilube hubs with seal holders;
• two straight Vesconite Hilube hubs;
