KUKA Highlights Robotic and Material Handling Solutions at Pack Expo Las Vegas
In several working demonstrations, KUKA Robotics will showcase various innovative automation solutions for specific handling applications during Pack Expo 2023 in booth C-3236 Central Hall.
For the handling of primary foods, KUKA, together with integrator Torfresma, will demonstrate the KR3 Delta HM robot in a solution for the primary foods industry. The demonstration exemplifies how KUKA automation provides increased production control while helping food-processing companies reduce operating costs, avoid failures and maintain high quality standards.
The KR 3 DELTA hygienic robot provides outstanding performance and value for pick-and-place applications for the food, packaging, electronics and pharmaceutical industries. The KR 3 DELTA combines precise grip, corrosion resistance and minimal maintenance requirements to excel in sensitive high-speed production applications. This ceiling-mounted robot offers a reach of 1200 mm, a maximum payload capacity of 3 kg and cycle times as low as 0.5 seconds.
The robot is made from corrosion-resistant stainless-steel that protects against dust and moisture. The design accepts alkaline or acidic high-pressure cleaning and disinfection up to 100 kPa for simplified upkeep and shorter downtimes. Food-sector certified for material safety, the entire robot carries IP 67 high-protection certification, with IP 69K for axis 4 that is also ISO 3 rated for cleanroom applications.
To boost the efficiency of product bag handling, KUKA will showcase a cell from Elevation Packaging featuring a KR IONTEC robot. Whether on the floor, on the wall or inclined, the KR IONTEC combines compact design with the largest working envelope in its class for optimal use of space. Equipped with a waterproof and dustproof in-line wrist and protected motors, the robot is suitable for almost every area of application.
For those palletizing lines unsuitable for extensive centralized automation, the CUBE cell will show PACK EXPO attendees a solution for easy, end-of-line robotic palletizing. The cell, from KUKA partner FOCUS Integration, features a KR IONTEC palletizing robot and is designed for lines where conveyance is too costly, or production rates are too low for justifying the investment of a centralized palletizing system.
