Zero-Max ETP Bushings Assure Fast, Accurate, and Concentric Mounting of Gears, Pulleys, Sprockets
ETP-Classic Keyless Shaft Locking Bushings provide faster, more accurate, and concentric mounting of shaft mounted components compared to mechanical shaft locking bushings. This field-proven solution has been used for over 50 years by tens of thousands of satisfied users across 5 continents and 30 different countries.
The ETP-Classic product was the first hydraulic-based keyless shaft bushing from ETP and it helped launch an expansion over the years into an entire family of ETP Products, including stainless steel versions of the ETP-Classic, as well as a series of single-actuation screw ETP bushings, among other specialized product solutions within the ETP family of products.
The unique ETP keyless bushing design uses a hydraulic principle, incorporating a double walled sleeve encapsulating a pressure medium. When its actuation screw(s) are tightened, the resulting hydraulic pressure forces the inner and outer walls of the bushing to expand uniformly against the shaft and hub of the mounted component. This hydraulic method for establishing the locked shaft connection evenly distributes the mounting forces to ensure a secure, repeatable, concentric shaft connection of 0.002” TIR or less. When the actuation screw(s) are loosened, the bushing relaxes to its original position allowing for fast and easy dismounting of the connected component. Many ETP keyless bushings can be used for over 1,000 mounting/dismounting cycles, including the ETP-Techno which is rated for up to 5,000 cycles.
Mechanical devices, by comparison, are not as accurate or repeatable for concentricity, as they rely on even tightening of multiple actuation screws to avoid excessive T.I.R. Mechanical devices are also much more difficult to position as precisely, In contrast, the ETP bushing and mounted component will not move along the shaft as it is tightened.
Check these important ETP features:
Quick
