A Guide to Trapezoidal Screw Jack Design, Construction and Selection
Alex Bronzini, Unimec North America
When you need to move a heavy load with a high degree of accuracy and safety, a trapezoidal screw jack is hard to beat. Because trapezoidal screw jacks are a well-established technology with an enduring design, you’ll find many high-quality units to meet your basic design needs. It is also easy to assume that there’s no difference among the many products available. However, not all screw jacks are created equal. When performance counts, some factors can make the difference between a good screw jack and an exceptional screw jack.
This article will provide an overview of some of the basic considerations to remember when you select a trapezoidal screw jack, and it will explain how screw jack design, construction, manufacturing, lubrication, and other factors can help your gearbox perform at its best.
Review the Basic Specifications
When specifying a trapezoidal screw jack, make sure you check the manufacturer’s datasheet for the following information:
- Load capacity. Refer to the screw jack’s datasheet for its static and dynamic load handling capabilities. Keep in mind that there is more to specifying a screw jack than knowing its load capacities. You will need to specify whether the screw jack will be configured for a compression or traction load.
- Input speed. Input rpm and gear ratios will help determine how fast the load can travel. Unimec offers standard ratios of 1:5, 1:10 and 1:30. Due to the friction that occurs between the internal gears and within the threads of the spindle, a high travel speed can overheat the unit. Using our testing machines, we have accurately calculated that trapezoidal screw jack input speeds should never exceed 1,800 rpm x 60 Hertz. Check your screw jack manufacturer’s reference charts for acceptable heat limits.
- Duty cycle. Screw jacks require intervals between uses to dissipate heat and do not operate continuously. Duty cycle indicates the frequency at which the screw jack moves the load.
- Other factors. These may include environmental conditions that affect the screw jack’s operation such as temperature and vibrations.
When lifting a load in compression configuration, the spindle may be susceptible to so-called buckling or deformation under the weight of the load. In this type of situation, refer to Euler’s laws for guidance on how to reduce the load. In traction mode, the buckling of the spindle is negligible. Also note that screw jacks are not designed to handle lateral loads. If your load is not perfectly centered, you must use a linear bearing to absorb the moment and thus prevent premature wear or possible failure.
An Enduring Design Versus a Fresh Approach
The traditional screw jack design consists of a metal plate supporting a rounded gearbox with a trapezoidal screw on top. Although this design is well-established, it has a drawback: To install the gearbox, it must connect directly to the metal plate and users must specify the screw jack’s orientation based on whether it will be subjected to either a compression or traction load. The flanged design also presents a potential weak point where the metal plate connects to the round section of the gearbox.
