Home » Minimum Design Speed Considerations for Sleevoil Bearings for Industrial Fan Applications
September 1, 2016
Slow speed operation of fan systems within the air handling
industry is generally performed due to two reasons: a coast
down operation is required for hot (induced draft) fans to
cool down before shutdown (often by using a turning gear),
and operational efficiency improvements can be achieved
during non-peak periods by slow speed operation using a
VFD. In either case, when these fans are supported by hydrodynamic
bearings, it is the oil film thickness developed from
the bearing-shaft interaction that limits the minimum speed
that can be maintained without causing premature wear and
bearing failure. This paper will present a brief overview of
lubrication theory and critical design parameters to achieve
slow speed operation.
