Automation Energy Motion Control Motor Controls Motors Sensors Product News Motor Design Motor Efficiency
Heidenhain Introduces Encoders for Small Motors
With the introduction of the PressFit rotary encoders from Heidenhain, small-motor manufacturers finally have a better solution for incorporating automated mounting for feedback devices. This new ExI 11xx encoder series features a unique compact design that allows fast and simple mounting by press-fitting into a motor housing while still allowing surrounding space for cables and seals. Heidenhain’s PressFit encoders are made for integration into motors with a flange size as small as 40 mm x 40 mm or an axis height of only 20 mm.
Developed in collaboration with global motor manufacturers, Heidenhain’s new PressFit encoders include a “PressFit” flange that can be secured in a motor housing through a frictional connection, using a specially designed tolerance sleeve. This innovative system promises to support automation efforts by easing mounting requirements, leading to less mounting time being required.
heidenhain.us
