Applications Helicopter Components Gear Drives Micromotor Motors Power Play
History-Making Micromotors on Mars!
Helicopter Makes Maiden Voyage Across the Red Planet with Help from Maxon
Space fans are thrilled: NASA’s Ingenuity helicopter has successfully completed its pioneering flight on Mars. This is the first time in the history of powered, unmanned spaceflight that a device has flown in a controlled manner on another planet.
A short flight for “Ingenuity,” but a big success for unmanned space flight. NASA’s Mars helicopter flew over the surface of the Red Planet for about 40 seconds on Monday, April 19th and landed back on four legs. From NASA’s perspective, this is a historic event similar to the Wright brothers’ first controlled flight in 1903.
With the Mars helicopter, the concept of powered, unmanned, and autonomous flights on foreign planets is being tested. This is comparable to the first Mars rover “Sojourner”, which paved the way for scientific follow-up missions such as “Curiosity” and currently “Perseverance.” “Ingenuity” is about to complete several flights over a period of 30 days, each lasting up to 90 seconds and reaching a maximum altitude of five meters.
Six micromotors control the helicopter’s flight direction
This article appeared in the June 2021 issue.
The flight is also a great success for Maxon. The helicopter is equipped with six brushed DC motors, which have been specifically modified for this challenge. The DCX series of drives, with diameters of 10 millimeters, control the pitch of the rotor blades and the direction of flight for the helicopter, which weighs only 1.8 kilograms and is solar-powered. The lightweight design is a prerequisite for a successful flight on the Red Planet, where there is hardly any atmosphere, comparable to conditions at an altitude of 30 kilometers on Earth.
“The biggest challenge in developing the motors was the extreme weight requirement,” says Aiko Stenzel, design engineer at Maxon. “Every tenth of a gram had to be saved to make the helicopter fly. What’s great is that despite the weight savings, we found a drive solution that has enough power to adjust the rotor blades. And this in the face of high vibrations and temperature fluctuations.” The standard variants of the DCX motors are available for everyone and can be configured online according to the individual customer specifications: shop.maxongroup.us
Eugen Elmiger, CEO of the Maxon Group, watched the NASA transmission of the first flight data live and is thrilled: “It is a fantastic feeling to know that our precision drives worked as planned and that we were able to make our contribution to this historic event. I am proud of our employees and look forward to the next milestones on Mars.”
Maxon’s drives are also used in the Perseverance rover. There are ten BLDC motors and a special gearbox that will be used, among other things, to handle the soil samples inside the rover.
Just like the more than 100 existing Maxon drives that have been reliably performing their duties on Mars, the motors for Perseverance are based on standard catalog products: specifically, nine brushless DC motors, the EC 32 flat and one of the EC 20 flat motors combined with a GP 22 UP planetary gearhead.
The engineers at Maxon closely collaborated with the specialists at JPL for several years to modify and extensively test the drives. The robotic arm on which the BLDC motors are mounted as well as the gripper are critical to the application and the success of the mission.
Learn more here: mars.maxonworld.com
