Figure 1—Compound planetary gear train within KISSsoft.
The drivetrain team faced an important technical challenge in designing an appropriate gear train that will be used when they transition to hub motors. Hub motors refer to electric motors being mounted within each wheel assembly, and the motors provide drive to the vehicle’s hubs via a gear train, avoiding the conventional drivetrain setup, which involves driveshafts.
With the electric motor and gear train being constrained to fit within the ten-inch magnesium wheels that they currently use, a compound planetary gear train was required and modeled within KISSsoft, as shown in Figure 1. Due to each planet gear consisting of two stages that are constrained in terms of the center distance for each stage, the macrogeometry tool within KISSsoft allowed them to obtain appropriate gear sizes according to the ISO 6336 standard whilst meeting our desired gear ratio. By defining the required safety factors followed by the specific conditions, the macrogeometry tool provided ear sizes that minimized and balanced the specific sliding of the gear mesh and provided hunting tooth ratios to improve wear distribution and minimize gear vibration. For their first electric vehicle entry last year, the drivetrain sub-team designed a custom planetary gearbox using KISSsoft. Following this design, they had a specific oil supplied by one of their sponsors in terms of yellow metal protection and viscosity. For the design of this new gear train, they wanted to incorporate the properties of this oil into the gear calculations. Within KISSsoft, they were able to add their own oil data into the software through the “own input” function which allowed them to alter the gear design to ensure their contact, bending and scuffing safety factors were met. Figure 2 shows the list of gear sizes obtained for the first stage of the planetary gear train.
Figure 2. Fine sizing results from KISSsoft.
Being able to model most assembly components within KISSsoft allowed them to define and adjust shaft and bearing sizes during the gear sizing process before creating the full model within SolidWorks. This can be seen in Figure 3, with it closely representing the KISSsoft model shown in Figure 1. Being able to do this within KISSsoft allowed them to save valuable design time with them limiting the iterative process of moving between KISSsoft and SolidWorks.
Figure 3—Full wheel assembly model within SolidWorks.
Another major advantage of modeling the whole system accurately within KISSsoft was the ability to apply tip and root relief to the gear profile design based on shaft deflection under loading. Using the microgeometry tool, tip and root relief were applied to the gear profile, which removed contact shocks as shown in Figure 4.
Figure 4—Tip and root relief added to remove contact shocks (circled in red).
Being able to implement tip and root relief into the gear design within KISSsoft is advantageous for them based on their manufacturing capabilities which are restricted to wire-EDM. Given their limitation to wire-EDM for manufacturing, they heavily depend on the accuracy of the gear involute model. KISSsoft’s capability to provide precise DXF files of the involute profile, including flank modifications, allows them to confidently send their designs for manufacture. This has been proven by the successful implementation of their first planetary gearbox in their electric vehicle. The support provided by KISSsoft had been crucial for the team to design highly refined gear train solutions.
