Manufacturing Wind Wind Energy Wind Power Wind Turbines Bearings Wind Turbine Gearboxes Industry News Bearing Failure Bearing Life Bearing Lubrication MRO Maintenance
A Sneak Peek at Quality Control at Atlantic Bearing Services (ABS)
This recent day in the life feature shows the ABS quality team in action to ensure manufacturing precision.
Antonio Martin Hernandez, Marco Partidas, Dayan Leng Armenteros, and Laura Vazquez diligently working on various components that require special attention. They are focused on inner rings (IRs) for cylindrical roller bearings, which play a crucial role in reducing friction and supporting radial loads. Additionally, they handle bevel gears, essential components in gearboxes that change the direction of torque transmission across various industrial applications.
Cylindrical-Roller-Bearings.jpgMarco Partidas, ABS Quality Engineer, working on ACB bevel gears, which are key components in gearboxes.
Their efforts also include working on a tail wheel, a vital part of the drive system for conveyors used in diverse industries such as sugar, cement, and mining. To wrap up the day, they are inspecting a main bearing housing designed for a wind turbine—a critical piece that supports the main shaft and ensures the turbine operates efficiently under heavy loads.
ABS-QC-at-Miami.jpgAntonio Hernández, ABS Global Quality Manager, working on inner rings (IRs) for ACB cylindrical roller bearings.
Each of the custom products from brands like ACB, AEC, and MGS Gears reflects an unwavering commitment by the team to delivering robust, reliable, and highly precise solutions under the most demanding conditions across a wide range of industrial applications.
ABS-Mecha.jpgLaura Vázquez and Marco Partidas from the ABS QC and Engineering Teams working on various mechanical components.
atlantic-bearing.com/corporate/a-day-in-the-life-of-the-abs-qc-team/
