Zero Wear Clutch/Brake
Torque is transferred magnetically with the PHT units, there is no friction surface to wear, which means that clutches and brakes have a very long life. Each unit has a variable set range, which can be fine tuned for a specific application. Torque is consistent throughout the unit’s speed range, making them ideal for tensioning applications. Units are sealed to reduce the chance of contamination.
