Warner Electric Develops Material Solution for Brakes
While cold rooms are essential for storing products in the food and beverage industry, the very conditions that allow preservation present a very real challenge to power transmission equipment. As any motorist will know, brakes can be particularly susceptible to performance drop-off in cold or moist conditions. To ensure that forklift truck brakes can operate reliably in cold room environments, Warner Electric has developed custom brake friction material that provides consistent performance despite extreme temperature variance and the effects of moisture.
Positioned in line with the motor or between the motor and the gearbox, spring applied electromagnetic motor brakes are utilized on forklift trucks to provide service and parking braking. OEMs typically require specialized braking systems for forklifts operating in the food and beverage industry, due to the multiple application challenges of operating in cold rooms.
Brakes must provide consistent performance in all conditions. However, moving in and out of cold rooms into different environments around the facility demands consistent brake performance across a wide temperature range. To present a further challenge, this variance in temperatures can cause condensation to build up on brakes, which can lead to another phenomenon: sticking.
Sticking happens when moisture causes standard friction materials to bond with the counter-friction surface when the forklift is parked. Consequently, the brake and motor are locked in place, stopping the truck, and causing downtime while maintenance is arranged.
With tight, contract delivery schedules for supermarkets, suppliers and other vendors to be met, having a forklift truck out of action for any period is undesirable in the food and beverage industry. To help improve uptime for end users, Warner Electric, a global manufacturer of electromagnetic braking solutions for forklift trucks, addressed these multiple environmental challenges with a new material solution.
Warner Electric has developed proprietary friction material specifically designed for cold room and outdoor environments with high moisture levels and wide temperature differentials. Developed and tested in-house, the new material retains stable torque characteristics for static parking and high energy stopping in tough cold and wet environments. Furthermore, it is specialized to combat the sticking phenomenon.
