W..9HG SPIROPLAN® Right-Angle Gear Unit
SEW-EURODRIVE
A Compact Powerhouse for Slow-Speed, High-Torque Applications
When it comes to motion control solutions that deliver performance, reliability, and design flexibility, SEW-EURODRIVE is a trusted partner to OEMs and machine builders around the world. One of our newer innovations, the W..9HG SPIROPLAN right-angle gear unit, reinforces that reputation by combining high gear reduction, compact size, and robust torque handling in a form factor that stands out in the market.
Designed for applications that demand very slow speeds, smooth operation, and maximum torque density, the W..9HG series is more than a gear unit. It's a smart, space-saving solution that overcomes the limitations of traditional compound gear assemblies, worm drives, and large helical bevel units.
Built for the Demands of Modern Equipment
Whether you're designing a conveyor system for intralogistics, a hygienic mixer for food processing, or a high-torque drive in a compact machine enclosure, the W..9HG delivers the performance you need without compromise.
With gear ratios greater than 2,000 and output torque capabilities up to 600 Nm, the W..9HG series provides the high reduction required for extremely low output speeds—but in a compact, right-angle housing that simplifies system design and integration.
This is achieved using a three-stage design: the first stage is our proven SPIROPLAN gearing, which ensures right-angle operation and wear-free performance, while the second and third stages use helical gearing to provide high overall gear ratios. This combination allows for finely stepped ratios and smooth, quiet motion.
Compact. Quiet. Capable.
Traditional solutions for high-ratio applications often rely on bulky compound gearboxes or worm gear drives. These designs may be large, heavy, or inefficient. The W..9HG turns this challenge on its head.
