Mining Bearings Plastic Bearings Plastic Gears Product News Agriculture Marine Water-Wastewater
Vesconite Bearings Confirms PFAS–Free Status Material
Vesconite Bearings is pleased to confirm that its long-established Standard Vesconite bearing material is completely free of PFAS (per- and polyfluoroalkyl substances) and has been since its development in 1969.
This includes the absence of PTFE (polytetrafluoroethylene), a commonly used fluoropolymer that is now increasingly targeted under international environmental legislation due to its persistence in the environment. With tightening PFAS regulations across the European Union, the United States, and other jurisdictions, Vesconite Bearings offers manufacturers, plant operators and OEMs a proven, compliant alternative that does not compromise on performance.
“Standard Vesconite was engineered from the beginning to be a dry-running, self-lubricating material,” says Vesconite Bearings CEO Dr Jean-Patrick Leger. “More than 50 years on, its PFAS-free formulation is gaining new relevance as industrial users seek to move away from fluorinated substances without sacrificing durability or efficiency.”
Standard Vesconite’s dry-running performance is made possible through internal lubrication that reduces the need for external greasing. This translates into smoother operation, lower maintenance, and longer service life — all without relying on environmentally contentious additives.
Importantly, Standard Vesconite’s composition and performance profile make it suitable for a wide range of bearing and wear part applications in sectors such as agriculture, water treatment, mining, construction, marine, and food processing. Its dimensional stability, low coefficient of friction, and chemical resistance ensure reliability in challenging operating environments.
“Standard Vesconite gives users peace of mind that their operations won’t be impacted by future restrictions,” says Leger.
“It’s a time-tested material that’s already helping companies meet compliance requirements while reducing maintenance costs and improving operational performance.”
For industries seeking reliable bearing and wear solutions that support PFAS-related compliance, Standard Vesconite remains a forward-looking, environmentally responsible choice.
vesconite.com
This article appeared in the December 2025 issue.
